Seems like you can get either 10 gauge or 8 gauge whips to go from the panel to the condenser. What gauge wire do people usually from the main breaker to the condenser panel? I won't need this in a conduit, and it looks like you can get 10 gauge romex style with 2 conductors and ground (3-wire) (flat sheathing), or you can get the 3 conductor and ground (4-wire) (round sheathing) in 8 gauge. Do people typically run the three or 4 conductor? Do people use the 10 gauge on smaller tonnage units? I'd like to have less IR drop so I'm leaning towards the 8 gauge.. But again, should I be considering something even thicker?
Any rules of thumb people can share with me? The condensors have a typical max current draw in the data sheet. It would be nice if there was a table that had 1. The length from the breaker to panel 2. The max current of the unit and 3. A resultant reccomended gauge of wiring..
If people don't have opinions on this, I'll just go with what the AWG guides suggest along these lines for a 30 amp breaker and then overdesign a little.
-Jeff
-Jeff
