Can more than 1 voltage run in the same conduit in a line across a building?
A AER · Registered Joined Jun 28, 2011 · 1 Posts Discussion Starter · #1 · Jun 28, 2011 Only show this user Can more than 1 voltage run in the same conduit in a line across a building?
B brric · Master Electrician Joined Mar 5, 2010 · 4,687 Posts #2 · Jun 28, 2011 Only show this user Generally, yes.
frenchelectrican · " Euro " electrician Joined Apr 12, 2006 · 5,369 Posts #3 · Jun 29, 2011 Only show this user Most case oui they do but some case no depending on what it run. Merci, Marc
Speedy Petey · Licensed Electrical Cont. Joined Feb 1, 2004 · 7,829 Posts #4 · Jun 29, 2011 Only show this user AER said: Can more than 1 voltage run in the same conduit in a line across a building? Click to expand... The answer is yes, but the answer is a vague as the question. When you say building, are you referring to a commercial building?
J Just Bill · Registered Joined Dec 21, 2008 · 3,118 Posts #5 · Jun 29, 2011 Only show this user 120V and 240V in ths same conduit, yes, either of those with com lines(phone, computer, etc), no.
