So I'll be installing 2 outdoor outlets and a light fixture, all of these will be flush mounted to the wall. 1 outlet will be on brick, the other 2 fixtures will be on a vinyl siding mounting block. Both outlets will be in weathertight boxes, tamper-resistant GFCI with outdoor covers. The wires will go through knockouts in the back of the boxes and directly through the wall.
Is NM-B allowable for this or is this something where UF would be required? I have 12-2 NM-B on hand and 10-2 UF, but I'm using my UF for the travelers on a 3-way switch inside the house for a the light on the detatched garage and I'm not sure I'll have enough left for anything else.
Also, for the light, is it allowable to use an indoor junction box behind the vinyl mounting block? Otherwise I'll have to find a money tree because the finances are locked down tight and I'm trying to have everything ready for rough inspection by the end of the weekend. Last little details.
