1 - 8 of 8 Posts
Hi! I just bought a preformed pond and found no instructions whatsoever on winterizing it. I'm in Canada and winters can get very cold. I'm worried that if I leave the water in as it freezes up might break the preform pond so what do I do? :confused1:
There are no fish or plants in it just a waterfall.
Retired Moderator
How deep and how big ?
If you empty it --it will be very likely to heave out of the ground----
Discussion Starter #3
Pond dimension
Hi! The pond measures 89''L X 54''W X 21''D with 163 gallons of water and a 500 GPH pump. None of my neighbors have a pond so nobody knows. I want to take good care of it so I can keep it for many years to come.:)
Maybe call around to some local landscaping companies and ask if they install ponds. If so, they should know how to take care of it, or at least know a couple manufacturers that you could call.
Retired Moderator
Sorry it took so long to get back----
Pump out about 1/3 of the water----that will provide some expansion space--
Add a few logs to the pond---helps break up the ice as it expands.---Mike----
Learning by Doing
Depending on where in Canada - Vancouver v. Ontario - very different advice.
- 21 inches isn't very deep for overwintering fish/plants in the pond - so you'll have to plan accordingly. My parents zone 7a (Virginia) have a 24 inch deep pond - They just leave the fish/plants in the pond over winter with a pump running to keep some of the surface water from freezing.
Retired Moderator
Leah--She said there were no fish or plants,
Pond is to shallow for over wintering fish in a cold climate---
Learning by Doing
Oops. Missed that. Thanks.
1 - 8 of 8 Posts
