Ayuh,... I'd close 'em All but the 1 in the basement, where the problem is,...
Just to save fuel,...
Yer lettin' a ton of heat outa yer uninsulated house...
An air quality company I brought in to assess the levels in our house was freaking out - apparently the highest total VOCs she's seen in a house. She recommended ventilating and the abatement contractor gave us a small negative air machine for that. The fumes are slowly getting better, though, but I don't want to stop ventilating. Thanks for the idea on a smaller fan, I think I may do something like that and hope the fumes eventually disappear. I may have to cut out the bottom few inches of drywall that they let the solvent soak into though. I'm not sure what the biggest source of the fumes are, though - the slab, the drywall, possibly bottom plates...?600 cfm is a ridiculous amount of air to be sucking though your house over an extended period of time in the middle of winter.
I happen to be rather sensitive to chemical fumes, so I understand your concern about letting the fumes build up but I think you're overdoing it. At a minimum I would rig up a lower cfm fan (like temporarily setting up a bathroom fan) and then just crack one window at the opposite end of the basement and see how that works.
I'd rather not seal the floor (I believe in eliminating the problem vs. covering it up). The abatement contractor mopped the floor with trisodium phosphate and rinsed with hot water several times.Can you paint/seal that basement floor? Or maybe hit it with a steam cleaner (a carpet steam cleaner).
It was mine. Some of the tiles were curling/clicking, a handful were broken, and I thought it'd be the extra-safe option to remove it. I wish I hadn't. None of the profressionals I brought in suggested encapsulation. Of course, everyone I speak to now does. I am a whirlwind of regret and stress over this (mostly from the fume issue that has no end clearly in sight - nobody has any good suggestions for its elimination - although it is slowly getting better over time).Who's idea was it to scrape up the tile? In most cases the asbestos in tile is fully encapsulated. This sounds like one of those fanatical ideas by someone that does not understand asbestos. Was it friable? Just wondered.
Yes, the mastic tested positive for asbestos.Many old floor tiles contain asbestos, but tile mastic can contain asbestos too. Did the company leave you a Material Safety Data Sheet (MSDS) for the product used to remove the mastic? Have you tried contacting the manufacturer and see what their recommendation is to abate the fumes? They may have a counteracting product to render it inert. Is the stuff flammable? Find out if the fumes are dangerous or just annoying. If it is flammable, is the negative air machine rated for a flammable atmosphere (most aren't)? Is 600 CFM the right amount of air flow? it may be correct for an abatement project (the machine is sized according to the volume of the area where abatement work is to be conducted), but may be way oversized for the situation you now have.
There is no flammability hazard with this solvent. It is rated for indoor use and is slow-evaporating for that reason.VOC Means Volatile Organic Contaminant. Volatile means fire, to me.
That's been on my mind a lot these past two weeks, but what they did seems to be SOP.The idiots that used a solvent on your floor should be drawn and quartered.
Is this just speculation or is there any fact to this? No other professionals or state regulators I've spoken with have expressed this concern.All the solvent does is wash the bituminous material away, which could leave the AB fibers exposed.
The only reason I haven't tried washing it again is because the contractors already mopped/rinsed the floor with trisodium phosphate several times. I'm hoping time is all that's needed for the fumes to dissipate, but we were at the 2 week mark two days ago and they were still present. I may give it another week and then try washing the floor and cutting out the drywall.A detergent wash on the floor won't hurt anything, so I'd try it.
Is this something I should be worrying myself about? Are my wife and I in any danger from this?Asbestos fibers in mastic act much the same as reinforcing rod in concrete. They bridge micro-fissures and keep the mastic homogenous. The solvent disolved the binder so that the asbestos fibers could be released and removed.
The contractors I hired said the fumes are usually gone the same day or within a few days, so this is certainly a stressful headscratcher.Nothing really wrong with thier process, but it's odd that the fumes continue to linger, unless they overused the solvent. We've removed the stuff mainly by scraping the bulk of it off, then disolving the very little that was left. Usually any odor is gone within a few days.
They did remove most of the mastic. There are still areas where the concrete has a dark stain, and some obvious areas underneath the drywall where mastic is still present. Here are some pics:"Is this something I should be worrying myself about? Are my wife and I in any danger from this?"
No. That is why you abate the mastic instead of just leaving it. Mastic left in place with no tile on top of it is much more dangerous since mastic is not designed to be exposed. If they've done their abatement work properly, there should be no mastic or asbestos fibers to worry about. I trust that they (or you) had a clearance air sample taken at completion of the work.
If they've gotten this solvent into the drywall, then you need to remove it. Drywall will easily wick anything liquid that comes in contact with it. If the solvent is in the drywall, it could take a long, long time for it to dry out. Standard practice would be to cut 12 inches above the level of exposure.
The white stripe is just drywall. I think I'm going to leave it because the fumes are almost gone now. I think I'll give it a couple more weeks before I do any finishing (putting baseboards up, installing carpet tiles, also considering sealing the floor), just to be safe. To my knowledge there is no insulation behind the walls.If that white stripe around the base of the wall is your trim I would rip it out and get rid of it. I would cut right through the drywall above the trim and get rid of the trim and drywall behind it. You can then get rid of any insulation that wicked solvent, pack the studs out to the face of the drywall, and install a wider (Taller) base moulding.
What are your concerns? Everyone I've spoken with seems to think abating the mastic is SOP, and I've really been goading them regarding any remote/potential issues. Just to be safe, I think I'm going to seal the concrete before I put new flooring down.Im sorry that someone misled you re the perceived danger re Asbestos. Like I said, its not dangerous unless its friable. Removing the bituminous binder was a mistake, IMHO.
