Hello,
My daughter has a window swamp cooler. When it rains, the floor inside gets very wet. I tipped the cooler away from the house. I tried adding a foam pool noodle to fill the gap. It is better, but still not good.
I was thinking of using metal tape to seal it up. I also thought of some type of awning. I am sure one of the more experienced people here will have a solution.
I need to stop the water from coming inside the house. I just replaced the subfloor and flooring under this window.
Any suggestions would be appreciated.
Thank you.
Thank you.
