We recently replaced our windows with the help of a friend who owns a sunroom company and helped us order and install them. We figured that he would know local code specs but should have done our own research.
When we had our
window inspection afterwards the inspector said that we needed to take the windows out to install the flashing underneath. The manufacturer instructions state that there are 2 ways to install and you can install the flashing before installation or after so we figured that protecto wrap after would be sufficient. We did protecto wrap outside under where the trim will go and used spray foam around all window edges and quad flash and the windows have a continuous nail fin.
The inspector usually inspects plumbing but was inspecting windows that day and I’m worried that taking the windows out to put down flashing underneath the windows (on the framing) and then putting them back in will do more damage and that the windows will actually be less waterproofed than they are now.
Any tips or tricks for something that we could do instead of uninstalling and reinstalling? Also it’s worth noting that almost all of the windows have a ledge of laminate countertop under the window. I’m not totally sure how you’d install flashing because of that surface. Picture below of that laminate countertop.
When we had our
