1 - 11 of 11 Posts
· Home Performance
It looks like that brickmold (exterior trim) is part of the window, so it may all need to come out. If that is the case, you may as well go with a nailing fin (new construction) install. What is the jamb depth on those? If less than 3 1/4", you'll need to rip down those jamb extensions as well.
There may be some other options, but it is difficult to tell by a couple pictures.
On product, if you are looking at Lowes, the Plygem Premium is the only thing that I'd recommend as decent.
Replacement windows will not work. Going to have to go with new constrution.
At the same time replace all that old brick molding with vinyl bick molding.
· Home Performance
I see... No easy way. Cut the siding back (or remove it), and then remove the window. The flange makes it impossible to remove from inside.... A replacement window could be used , but it would need some high-level metal work to be flashed properly. Your best course of action is a new construction window.
· Home Performance
Generally speaking, yes. Unless you see screws through the jambs.... Remove the glass and then get a pry bar behind the fins. You have already done the hard part in getting the nailing fins exposed for removal.
· JOATMON
I'm installing new construction windows in my addition....they have the nailing fin that goes all the way around....if you want, I can post up some pics....
For the most part, new construction windows look like they would be your best bet....but a little late in the year to be doing it....
1 - 11 of 11 Posts
