Our New Windows
I am looking to replace five, double-mulled windows in our home. (Photo 1) These are original builders double-pane with storms. I hope you might be able to answer a few questions for me:
1) I am not sure whether to do new construction or insert replacements. Having a real solid window with the least frame area and glass areas loss is most important.
2) I have been looking at Marvin's Infinity fiberglass collection believing fiberglass is strong enough to have minimum size frames, but I am surprised these seem to take up an additional inch on both sides. Right now, the frame width of the sash is 2 inches, which gives us a really nice, large glass pane area.
Do you know which brand/model maintain might maintain the largest glass area for these double-hung?
3) I really would like to do these myself, but I have a few questions about doing full new construction replacement...
a) As per Photo 2, the current windows are surrounded by brick molding and a j-channel.
Couldn't I just remove these windows, add new windows with flanges and flashing tape from the frame to just under the existing J-channel with our removing it. Of course, I would be going a down to studs. I thought maybe because the J-channel is already flash taped underneath this might work. Caulk heavily below the flanges and over flash tape again. Seems like one could actual tuck the new flashing tape under the existing j-channel by about an inch because the nails are not right under the channel itself.
Would this work effectively and be water-proof.
b) As per Photo 3, the doubled up windows are already mulled with a stud in between and molding on top. Could I just replace both windows and overlap the flanges...then flash tape so I don't have to remove the center frame and put in fulling mulled double replacement? Would this work? As a note, these current, ancient (30 year old) wood windows have never leaked using this configuration.
c) FInal Idea...after looking at these windows the j-channel is not particularly appealing. I was thinking of another option. Is there a way to route channel on the backside of a wider brick molding so it can lap it over the j-channel to hide it. (Photo 4). Certainly a non-standard approach, but I am always thinking of new ideas and ways to make my projects more difficult.
Thanks!!!
Beerski
Thanks!!!
Beerski
