This is one of the last details I need to decided on with my new workshop. It is 3500 sq ft with 2x6 (16 ft high) walls. I am covering with pre finished Hardie plank nailed directly to the stud frame (house wrap between). No sheeting. This will save about $5K in material.
I have watched dozens of videos and read a bunch of articles ... now more confused more than ever!
The first problem is what to make the casing out of. I used PVC on the house. I was not really happy with it. The biggest problem was the expansion / contraction ... I have a large number of caulked joints opening up. I also don't like the finish (cut ends are rough).
So, I figured since I am using Hardie (cement board) on the walls, why not for the trim. The first problem how to cut a groove for the nailing fin? Cement board does not cut well ... especially on a 6 ft long groove. I guess I could space it out but with what?
I thought about wood. Unfortunately the window trim would then need painting (Hardie plank has a 15 year warranty on finish ... 50 year on product).
Still it might be my best option. What kind of wood would you use for external casing? Any special primer (I will give it two finish coats) that may help weatherproof the casing?
OK ... then my second question .... flashing. I watched your videos ... simple to flash a window without a casing. If you have a casing, do you "double flash" ... once on top of the window and then a second time on top of the casing (you will have a large step where the siding hits the casing)?
What about at the bottom of the window. Do you need some kid of flashing to let any water that get in around the window out before the siding? In other words, flashing under the bottom window casing?
This is one of the last details I need to complete in the design. Any advice would be greatly appreciated!!!!!!!!!
