Hello!
I recently bought a 15,000 btu window unit Off of Craigslist. The seller stated that the unit was two years old and did not cool as well as it used to and possibly needed a “recharge”. Once I installed the unit I came to realize that this unit was not cooling whatsoever, Essentially just functioning as a fan even when I’m cool mode. The unit it perfectly clean as if it were brand new, however I cleaned the filter anyway as this is all I know how to do in terms of A/C maintenance and repair. After a bit of research I am wondering if maybe the compressor is broken? The unit is very quite and really only sounds like a fan, so maybe the compressor is not even turning on at all and that is my problem? Or is there a way to “recharge” the air conditioner?
Has anyone had any experience with this unit before? And what does this sounds like/how do I fix it DIY?
Thank you!
Thank you!
