1 - 11 of 11 Posts
I am planning an attic insulation project and am thinking I'l pile up cellulose to get the whole attic to R-50 or so (being careful not to overload the capacity of the drywall, of course). Right now the furnace ductwork is in the unconditioned attic and is barely insulated at all. The flex ducts have like R-4, and the sheet metal trunk duct is just completely exposed with no insulation at all(!). The ceiling already has around 6" thick fiberglass batts between the 2x6 bottom chords with inconsistent and ineffective amounts of cellulose on top. The duct layout is not bad.
There's no mastic or anything nice like that, so I would like to air-seal the ductwork even though I don't anticipate using the furnace much (after all the energy projects, I should be able to get by with a medium sized ductless mini-split heat pump/AC). However, if I pile on 12"+ of cellulose over the ducts, is there any chance that after it settles, that will be a decent enough air barrier? Or should I just bite the bullet and mastic the hell out of the ducts or encapsulate them in spray foam before spraying the cellulose?
Discussion Starter #4
Ugh, I was hoping you wouldn't say that… The attic is super cramped and scary to work in. Guess I'll just have to figure out a way.
Super Moderator
Yep, seal the ducts.
Bill Kearney
Best bet, pay someone else to suffer the job. Cramped spaces, heat, and the like, ugh. Make sure when you're up there someone else is in the house and keeping tabs on you. It'd be a shame to die from heat exhaustion trapped in your own attic, just to avoid paying someone else to do the job...
Exterior Construction
1 - 11 of 11 Posts
