Hi -
I have a 15amp circuit that has a half dozen porcelain pull-chain lights in my basement and a handful of three prong receptactles on it. It was not grounded, and I went to find out why. It's wired with 12-gauge three wire romex. The first two lights on the circuit showed the problem - the neutral and hot are connected, but the ground wires are neatly clipped off at the end of the sheathing, just inside the electrical box. This is the case for the incoming and outgoing feeds at the first two boxes on the circuit, and then the rest of the circuit appears to be wired properly with ground connections.
It looks to me like the whole circuit was done at once, since the material and style is consistent throughout. I assume (but can't know for sure) that the electrical work was done in the mid-late 1970s when this old house was rehabbed and knob-and-tube was completely replaced throughout. The house is in St. Louis, and the wires aren't encased in conduit - they just run through holes in the joists.
Because the ground wires are cut off so short, I've got no way to hook them up without doing some rewiring and maybe moving a couple of boxes.
Does anyone have an idea why someone would choose NOT to connect the ground wires, but rather cut them short to make the connection impossible? It seems absolutely nuts to me.
