Actually being a sub panel the neutral and ground needs to be separate. The bus supplied should be used as the neutral. Leave the screw out that bonds it to the metal case. You need to go and buy a ground bus kit that will fasten direct to the metal box. I believe it will fasten to that raised lump in the upper right.
