Hi,
I am planning to insulate my garage. The garage is unfinished, but the builder has finished the portion of the garage that shares walls/ceiling with the living space. The house is only 6 month old.
The rest of it is unfinished. When inside the garage, I can see at least four square openings that the builder has cut into the walls. I guess they are related to soffit ventilation.
I have many questions, please help me!
1- What are those holes for?
2- Can I cover them with plywood and then insert the insulation bats into the space between wall studs? If not, there will be no point in insulating the garage, since cold air can move inside?
3- I live in a cold area (yeah Ontario,Canada!); all I need is to sit in a warmer car when I want to head to work....the garage won't be heated, I just want it be warmer than -19! Should I put vapor barriers? or simply insulation bats held in place by friction?
4- Fire proof insulation, or simple traditional pink ones for garage?
I appreciate any answer to any of the questions above. Thanks!
***I have attached the pictures of the wholes, and an outside view of the garage for clarity.
