Hello,
We are renovating our 1600 sq ft. house. It is stripped to the studs and joists. There was no insulation at all anywhere in the house. The question is what is the best quality and most cost affective insulation to go back with. I was thinking just bat the walls and blow in the attic insulation with baffles on the sides. However, I am wondering about possibly using rigid foam? Is this a good idea, how would you go about doing this? I've seen someone on youtube cutting rigid foam then spray foaming it in place around the edges....dumb? I cannot afford to spray foam the whole house and due to keeping the historic windows, I'm not sure it would be worth it anyway. Also, brands for blown in insulation would be helpful. Also, I've heard mixed opinions on whether to use kraft paper backed or unfaced. I am in Zone 3, Southern Oklahoma. Thanks for any advice you can give on these matters. Electricians and plumbers are starting this week so insulation will be coming up soon!
