I'm not sure exactly where this question belongs, but here it is. After experiencing power outages lasting 8-1/2 days and 2-1/2 days in the last several years, I've bitten the bullet and contracted to have an automatic back-up generator installed. The company I chose is the one PENELEC uses in our area when you request a referral from them. Anyway, when the estimator was here, she chose an installation site that makes me a little nervous, so I thought I'd ask you guys, because I know I can trust your advice.
The reason for my concern is that the prevailing winds at my location blow toward this end of the house about 90% of the time. I currently have a portable generator that was put into use during the last extended outage. About 3 hours after it was started, my CO alarm went off. Needless to say, there was no smell or any other kind of warning; I wasn’t even having physical symptoms yet, but the alarm was right and probably saved my life.
I definitely don’t want to have that problem again, so I’m concerned about the proposed location being so close to the basement window, which is single-pane glass in an aluminum frame, and the attic vent at the peak of the house. Not to mention that all my windows are original to my 1970s house, so the wood has shrunk and, even with storm windows, they leak like sieves in many instances.
SO … Is it better to put the generator where the exhaust will blow against the end of the house, [Location-1] or to remove the “trees” and put it beside the deck where the exhaust will blow down along the side of the house [Location-2]?
