I am researching dehumidifier installations and need some help please. I live in southeast Texas where it's humid most of the time. I recently built an ICF home and have noticed that the humidity runs between 60% and 75% most of the time. I do have an ERV but due to the outside temps and humidity levels it doesn't get much use. I have an energy efficient central AC unit (Trane XL20i 5-ton 2 stage) but with the concrete walls the temp stays around 70F so it hardly runs, and when it does, it doesn't run long enough to remove the humidity.
So now I am looking at installing a dehumidifier (Aprilaire 1870) and in reviewing the installation manual I see that their preferred method is to install the intake for the dh to the air return, pass through the dh, then return the air on the other side of the AC unit to the main supply plenum for distribution to the whole house.
The AC contractor wants to make this a standalone system and basically cut two new ducts (intake and exhaust). This is an alternative installation in the Aprilaire manual but not the recommended one.
My question is this - which is the better installation and why? It seems that by pulling the air from the main return duct and then returning the dehumidified air to the supply which is sent all through the house as opposed to a more localized distribution. I'm not an AC expert but I would like to be informed when talking with him so I can feel comfortable it's done right if he is recommending something different than the manufacturer.
Thanks
Thanks
