did u know the 327 has been discontinued? the 320 takes it's place.we use the testo 327-1. nice you can set up to use the way you need it to work....and the bacharach 24-8447 its kind of pricey it also does natural gas, propane,coal, wood, kerosene oil...like them both..ben sr
That was introduced about the same time as the 320.Bacharach Insight.
Is that Insight made here (gonna buy the 320 and a second analyzer for back-up)? Uncle has been a Bacherach man all his career til Testo came on the scene, so I had to choose between the two for my primary CA.Can use it as a manometer also. So I have my manifold pressure printed out on the slip with my other readings on gas, draft reading on oil.
I still have my tech 60, which reads much faster then the Insight, but doesn't print or do draft.
