I am getting conflicted information on the topic of wiring a sub panel to a remote building. 1. Some say to use three wires (2 conductors and 1 neutral) from the main panel run to the sub. Run a ground wire from the sub to an 8' ground rod. 2. Others say to run three wires with a ground from the main panel to sub, both ground wire and neutral wire connected to the neutral bar in the main, and then seperated in the sub panel. Ground wire to a ground bar and neutral to an unbonded neutral bar. 3. Some say the same as #2 but, with the addition of an 8' ground rod also connected to the sub panel ground bar. Which is best? Any help is huge!! I shut my eyes and all I see is balls of tangled copper wire of all sizes and types!
I built a work shop to roast coffee from. I installed a square D QO box. 100 amp with main breaker. I just finished digging my trench 16" deep, and ran my conduit. I purchased 4 runs of #6 thhn 100' in length. Sub panel is 75' from the main panel. Main is 200amps. I am installing 60amp double pole breaker in the main to feed the sub panel. I will use the 100 amp breakers in the sub as my safety disconnect. I am ready to run my wires through the conduit, but want to know if it's best to run three or all four wire setup? Thanks for your reply, Brian
