Good evening everyone.
Let me start by saying that im a first time homeowner living in my newly bought home that was build in 1950 in Sayreville NJ.
My mast head was blown off during the recent hurricane and water came into my breaker box causing it to blow.
I am having a new box put in and the mast head is being reset.
I have taken the face plate off my breaker box and notices some alarming things.
Firstly I noticed that the incoming wiring to my breakers has a smaller gauge ground wire; ive measured it at 16 gauge. the other 2 wires are 14 gauge
I then began to search and noticed that my entire home was wired with this wire 14 gauge on the 2 lines and 16 on the ground.
I traced the wires into my attic crawlspace and come to find that in the attic and behind most of my walls there is the old asbestos sheathed wiring.
My question is: now that im having the box swapped out. Should i have all this wiring removed and replaced to bring my home up to code?
Thanks for any help.
Please do not respond with advice to save me money; I only want to know if this wire with 16 gauge ground and asbestos sheathed wire is needed to be replaced for code purposes.
If anyone could post wording for the code that would support the need to replace all the wiring; I would appreciate it.
Thanks all.
Thanks all.
