I have my relay set up as you can see in the diagram. I followed grayfurnaceman's video on Youtube but he used a 90-370 relay so I'm not sure if I managed mine correctly.
The original idea was to finally get my Nest working with a C-wire. It unfortunately did not work. I believe my Nest has other issues now (it won't even turn on when plugged into the wall via USB). However, I put my old Honeywell thermostat back on without batteries, and it doesn't turn on either. I put the batteries back in and everything is working normally. Is there something wrong with my set up? It's odd that everything except the C-wire still seems to be working.
Thanks for any help.
PS - anyone have any luck getting a new Nest out of warranty? It sat on my shelf for 2 years before I got around to this C-wire install and now Nest just says they can't replace it because it's out of warranty. Thanks Nest, it was your fault in the first place....
