If you’re located in a climate where indoor air gets dry in the winter, and there is a humidifier upstream of the filter, the white particles may be mineral deposits left behind by evaporating water. A properly running humidifier should be putting only water vapour into the air, leaving the mineral deposits behind in the unit. A malfunctioning unit may be putting liquid water into the air stream, along with the minerals dissolved in the liquid.
Chris
