I have a whirlpool dishwasher model gu1500xtkq0, that is not draining out all the way. Once the cycle is over, there is still a good 2 inches of water left in the bottom. I first thought it was the check valve. Inspected it and it looked fine. So I'm thinking it is the drain pump that has gone out. I have found the pump on line for about $35. How involved is it to replace? Or could it be something else the matter with the washer?
make sure the drain hose is properly installed..and not sagging...:yes:
#1 HAWKEYE FAN
I wouldn't replace the pump until you inspect the drain hose for an obstruction.
