Don't laugh at me please. I have a Living Room, that leads to 2 hallways and then 3 bedrooms...all in laminate.
I made a nice picture showing the way I was thinking of running the boards.
Good to go, as I am having a debate with my dad - he thinks E and F should be run North and South and make a transistion between the 2 hallways.
Also wondering if you'd go directly from hallway to bedroom continuous or would you make a transistion from hallways to bedrooms?
Thanks!
It's personal preference. If you want the back rooms turned North-South then I would recommend carrying the E-W flooring in the hall all the way to the wall and then have the change happen on either side. This way when you are looking down the hall from what I assume is the living area you don't see the flooring transition.
Ditto on the personal preference... thoughts to consider are
--- running it crossways to incoming daylight will hide structural imperfections
--- down a hallway will make hall look long and narrow versus crossways will look shorter and wider
--- doorway transitions will make installation easier , direction change possible, but leaves um.... a bump :)
DON'T FORGET KNEEPADS! :)
