I'm switching out our old cream light switches for white ones. On the new light switches, you can secure the black wire under a side plate by winding the associated screw. There are two side plate/screw combos on each switch (in addition to the ground one). What's confusing me is that there are two slots under each plate/screw combo that you can slide the wire into. One side looks simple while the other sides as an additional tiny tab. Photo of this is attached with arrows showing the two slots.
If I wanted to, can I make a shephard's hook and hook it onto the screw instead? I would prefer to use the slots though since it's easier.
Also, the wiring is two blacks and a bare copper wire. Does it matter which gold side screw/plate combo the black wires are terminated to? It seems like it doesn't but just want to make sure.
