I have a bathroom floor that had particle board glued and screwed to every single square millimetre of the plywood underneath. I've managed to scrape the particle board off but now there are lumps and bumps of leftover particle board on the plywood. Any advice on which sander and paper to use for this? (replacing the plywood is not an option
If sanding, even with one with a dust collector, you'll need the bath window open with a strong fan in the window blowing outward, the door open plus a good respirator.
What's the plan for the finished floor?
How thick is that subfloor?
Your going to spend far more time and money on a sander, all the belts needed, floor leveler and end up with a weaker floor by trying to reuse what there now.
The only way to salvage that floor "IMHO" is to take it out and replace.You will spend more time dealing with it and end up with a crap subfloor after all of your work.
Try placing a soaking paper towel over a spot, see how much the particles soften. Soak the towel every few hours, keep the spot wet and try scraping after about 1/2 a day. If the glue/particles can be scraped away to relatively flat (1/8" of the stuff left over? - I'd call that success), you can trowel thinset and cover with cement board. Same operation with paint thinner or such. If nothing works, scrape as much as possible, seal with primer or redguard, thinset and cement board. Predrill and countersink the board and you can adjust the board - edges meeting, etc. Blunt screw will bring the board up. Too much adjusting will break or weaken thinset. Dry fit the boards first.
I never tried, but I'm guessing particle board may soften first. Plywood is more resistant to damage so don't worry about it.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DIY Home Improvement Forum
