I am watching over you, no worries. Be PROUD of yourself, and no need to explain your gender. Those who will take THAT under consideration are not worth paying attention to anyway.
just last word. Make sure you have that connector on the port REALLY tight and wear thick gloves. Refill cans you buy in stores are notorious about being loose on connectors, then you spill more, than goes in. Plus, you frost bite your fingers.
Give it short bursts and re-check on function/pressure. If by any unlucky chance, you overcharged and system locked on you, you can, ahm, bleed some out via port. Not nice to do, but is effective. Just like you bleed air out of your tire.
