The shower was installed in 2003. I don’t want to pull it apart until I know which cartridge I need if possible.
Attached pic
thank you
Super Moderator
Welcome to the forums Gregg.
Your picture never posted.
I responded so it should post now. Try again. Thank you.
Attached pic
thank you
You're better off removing it so you can be sure what cartridge it uses. Unless you can find a model number and serial number on the fixture somewhere? Google that question as you may get the exact spot where the identifying numbers are located. Also get info on removing and replacing.
Once its pulled out make sure you know the steps to put it or a new one back in. Its very easy.
Without a model number, you will have to follow J.V's recommendation.
Or, you can take your picture to a plumbing supply place for ID.
