Pre hung, just to be able to install the new one with the lock set.A standard door is 80 inches and the width is usually on the 2" so 28-30-32-34"
Are you looking to by just the door slab or a pre hung door with the jam?
For a prehung 30" door, the rough opening in the house framing would be 32x82 about.
Hmm, a pre hung comes complete with the jam and hinges. What exactly are you measuring.Pre hung, just to be able to install the new one with the lock set.
Edited since I found my answer
Thank you!
Let me give it a shot. The NOMINAL door size usually goes in 2” increments in width and is 6’ 8”. To the top . So for a door labeled as 2-0 the actual door itself less trim would be 24” wide. Then you normally add 3/4” to each side for the jambs bringing you to 25 1/2 and 1/4” each side for Adjustments so you frame 26” width. That said, if you are gonna screw up the rough, best to err larger than smaller. I CAN fit a 2-0 door nicely into 27; 28, or even 30” openings, but no way in hell it goes into a 24” rough.The dirty little secret of house framing is that measurements are only accurate to a quarter inch (0.25") so conceivably a door could be "off" (weasel word) up to twice that or 1/2". A half inch to left or right of where it's supposed to be or and(!) a half inch wider or narrower than it's supposed to be. That last is a major fail but has happened.
The extra width is supposed to be taken up by shim wedges and _must_ be two in each position.
(About now somebody's going to call BS on me. Well okay, but in some other universe not in the world I've seen.)
So when you look at a door you are actually looking at the slab width + 2 jamb widths + 2 gaps. So a 24" door could actually sit in a hole of 28" wide. Rant over.
