Hello everyone. I need to replace the cable that connects a 200 amp main shutoff on the back of the house to the 200 amp electrical panel in the utility room that is about 12' away from the main shutoff. The existing cables are 2/0 aluminum and need to be updated to 4/0 AL.
It looks like I need 4/0-4/0-2/0 AL cable with maybe a 6 ground wire? I'm less sure about the size the ground wire needs to be than I am the other wires.
I am also having a hard time figuring out exactly which cable to get. There is conduit that runs up the outside of the house from the main shutoff, then through the attic, and down to the box in the utility room.
Would you go with SER cable? Or MHF? Or something else? I know the SER does not need conduit, but what if conduit is already there?
Thank you in advance for any advice. I appreciate it.
