The central AC in my 480 sqft shop/office went caput. The air handler is in the attic. The building has two 240sq ft rooms. I have been advised to go with either a mini split system, or just cut a hole in the walls of both rooms and install 2 window units. I'm not really too keen on the latter idea. What if I installed a 2-ton mini split unit in the back office wall, then used the existing air handler ,which still works (in the attic), to circulate air through the rest of the
building?
