Greetings:
I am finishing the basement. I drywalled before putting the return vents. I have pictures and can locate where the return ducts are and will be able to cut and put the vents. In case of rooms where the return ducts may not be running through, how do I put the return vents and be code compliant. Attached is the layout with approximate size of the rooms.
Thanks!
Shaw
Thanks!
Shaw
