1 - 7 of 7 Posts
I'm looking for a simple bracket to mount a really heavy whiteboard on my cubicle wall. I know exactly what I want, but it doesn't seem to be out there. Can anyone help me find or maybe suggest how I could make without a metal bending break?
The brackets should look something like this:
Metal, preferably with several screw holes drilled in the center of the 4inch side.
· Usually Confused
They look like they would do the trick. If you wanted more security you drill some extra holes on the down leg or as mentioned, use 3 or 4). All your weight is shear - straight down. Take a look at the load ratings on simply picture hangers. Even little ones are good for 10-15 lbs, each.
1 - 7 of 7 Posts
