1 - 6 of 6 Posts
In a shower, the vapor barrier(Keri’s/waterproof paint etc) is there to stop any moisture that moves through the tile / grout. The moisture would make its way to the bottom of the wall running down the barrier to the where it meets the pan. Now it’s stuck as the tile has a silicone bead/barrier that fills the gap between the tile and pan. does this moisture go?
Not sure what the question is here. Are you talking about a tub shower, or a custom tiled shower with a tiled floor? Because you mentioned "Keri", which I assume is supposed to be "Kerdi", and that definitely doesn't work the way you guys are describing.
1 - 6 of 6 Posts
