1 - 2 of 2 Posts
Hi all,
I have a lamp from about 6 years ago that I'd like to repair. During a move, the power cable (which is connected directly to a small white light fitting which held the globe) got damaged when the cable got pulled out of the fitting. Both the globe/fitting and cable have since been lost. The white bracket was mounted by a wire frame in a circular bracket with about a 30mm (1.18 inches) diameter.
Just wondering where the best place would be to buy/obtain a fitting + bulb + cable that might fit in the lamp? Is there a common 'standard' of light fittings?
Any help would be appreciated.
Cheers,
Gavin
1 - 2 of 2 Posts
