Switched Hot and Neutral - Issues?
Hey folks!
We recently installed a Panamax M5400-PM Power Conditioner for our Home Theater equipment, and it turns out that the Panamax "Wiring OK" indicator light stays off -- meaning there is an issue with the outlet it is plugged into. I bought an outlet tester, and it indicates the outlet is good. I also did a run through the circuit breakers and found another outlet on the same 15A breaker that had Hot and Neutral switched (according to my tester).
Could that be the wiring issue? Or should I have ground checked? The apartment we are in is in the top two floors of an older house that our landlord indicated used to be wired for two-wire outlets. In fact some of the 3-way plugs are also "open ground" plugs that are on different breakers from the Home Theater equipment.
Any advice? Could the switched Hot and Neutral be my issue?
BTW: My other concern is that we get low voltage when the HT equipment is on (100 - 110 Volts). That is why I bought the Panamax in part as it does Voltage Regulation too.
Thanks in advance...
Hey folks!
