1st, were you using a strong enough load for the gun ? if you got enough penetration for some, its possible the conc was more heavily mixed w/extremely hard coarse aggregate but unlikely,,, p/t is the correct mtl for a btm plate on conc,,, the reason to 'shoot' the plate is to allow it to resist lateral force/load as gravity keeps it where it is placed,,i'm not aware any rqmt that so many devices per foot be installed,,, you could use a hammer drill & insert sinusoidal anchors or lead-shield ( drop-in's ) anchors in place of shot nails.
we're presently partitioning off bsmt furnaces & creating exercise room - 20' has 5 anchors,,, doubtful your temps are much lower than ours in atl - just hold the tight against the btm plate ( probably redundant - most don't 'fire' until the safety is depressed )
