I recently connected a Venstar T1100 wireless thermostat to my Carrier 58STX070 gas furnace. When I have the thermostat set to heat, and the heater running, the HVAC system will randomly switch over to Air Conditioning and blow freezing air. This is not fun when waking up at 3am with the room at 60 degrees.
The receiver end of the Venstar (T1100REC) will show the heater light on when the heater is running. When it flips out and goes to A/C, the heater light is off and the main power light is very dim. The only way to get the A/C to shut off is to pull the receiver off of it's base, which disconnects the wires from the base that lead to the HVAC system. I then re-seat the receiver and the heater works again.
There are 4 wires for the HVAC: Red, White, Yellow, and Blue (labeled G). The previous thermostat (Honeywell), had a jumper from the Rc terminal to the R terminal (wiring photo here). The new thermostat only has one R terminal (wiring photo here). The Venstar manual has a diagram that shows how to hook up a 4 wire system, and I've followed those instructions.
Anyone here have any insight as to what could be causing this? And, what can be done to fix it? I'd hate to reconnect the old Honeywell thermo because it is downstairs and the heater would never turn off on it's own. It would never get warm enough downstairs; the furnace is upstairs and most of the heat stays up there.
