I've tried a couple of different ways to deal with my low-producing well. The well is old. I've done a bunch of measurements/tests to characterize the production. The well can produce about 35 gallons of water before it dries up. It recharges at just over 1 gallon per minute. My current setup just resulted in a water-logged tank that looks to have a busted bladder. Here's the setup:
- 1 hp submersible pump
- pressure switch with low pressure cutoff (cuts-off pump when pressure is below 20 psi)
- 1/2 hp booster pump between the pump and the pressure tank that is tied to the pump (pressure switch activates both the submersible pump and the booster pump simultaneously)
- 86-gallon bladder pressure tank
- system at 30/50 psi
This is a backup well and I'd recently switched it over to test the capability. I noticed recently that the low-pressure cutoff actually never cut off when the well dried up but the system seemed to be working fine, so I let it go. With 4 people in the house (and 1 that takes really long showers), I think the well dried up, but the system never shut off, somehow leading to the pressure tank becoming water-logged. Normal water usage in the house didn't stress the system too much. It's only when my kids came back from their other homes (we have a blended family) that it seemed to have a problem.
I'm going to re-do the entire system. I've got an idea of what I need to do:
- remove the booster pump
- install new pressure tank
- replace pressure switch with standard switch (no low-pressure cutoff)
- install pump-saver
I think this setup will simply cutoff the water pressure when the well goes dry and prevent both the submersible and the pressure tank from becoming damaged. We'll lose water pressure occasionally, but at least the system will stay intact. As I said, this is our backup well so it's not critical. The only reason I like to switch to it on occasion is to keep the water moving in the backup well to (hopefully) prevent further scaling, etc. on the well screens.
Does anyone have any recommendations, or does my proposal sound like it will work? I appreciate your input.
