1 - 9 of 9 Posts
I currently have a finished basement with laminant wood flooring. The stairs leading down to the basement are wood and I am planning to stain them but there are a couple small holes between the actual stairs and the drywall. I want to use molding to cover the holes and give a finished look but I'm not sure what covering is best suited for it.
Drywall contractor
A picture would help. Is there a skirt board between the steps and the drywall??
Retired Moderator
Can you see under the stairs? It might be easiest to remove the treads and risers and add a skirt board if the stringers are far enough away from the framing.
Framing Contractor
No moulding is going to hide that cable running up and under the top tread. A skirt could still be installed now, but it will be a pain.
Drywall contractor
Yep, pull the treads and risers and add a 1"x skirt board....
Reactions: joecaption
I'd just caulk the gap. Blue tape the wood and latex caulk it. Then paint it the same color as the wall.
Super Moderator
Home Depot or lowes sells shoe molding that can be stained. Perfect for these steps
I don't think the fellow is coming back, he made only 2 posts since 2011.
1 - 9 of 9 Posts
