1 - 11 of 11 Posts
I have roughly 60 or so 14" to 16" pieces of 2x4's. They were left over from a job I am doing in my basement. Can I use these pcs as top and bottom plates for walls? I was thinking that I could line them up, drill them into the floor/ceiling and then cut studs to size. I then thought about the integrity of a wall created that way and did not think that it would be stable.
If I cant use them for what I mentioned above then should I just throw them out? I would hate to waste so much wood.
General Contractor
You can use them for fire blocking, general blocking, cripples, firewood (if untreated), or for wood working projects.
Discussion Starter #4
Thats right! I completely forget about that. I was going to cut sheet rock pieces for the fire stops, like the building inspector told me I could do, but I can use the 2x4 pieces instead.
You just solved my dilema.
Thanks.
Banned
I save scrap wood for fireblocking
Smaller pieces are burned in the fireplace
I don't have a ton of scrap
Since I'm finishing up my project I'll be burning off a lot this winter
Don't burn PT - very bad
Two of my often goto items:
1) scrap wood pile of project left-overs
2) screw and bolt bucket of project left-overs
:thumbsup:
I'd use the wood scraps to make fertility gods.
Ron
Discussion Starter #9
Fire blocking is enough for now. I'll take some of the suggestions and use them during another project. lol
There are some good places to put some shorts like that. In the corners at the bottom for the base trim to attach to-if you don't put in a little block the top nail does not have a good place to sink, unless you go for an extreme angle. Same with crown-it is good to have some backing for the nails. Also, backing for things like paper towel holders, toilet paper holders, places for handrails to attach.
And fire blocking : )
1 - 11 of 11 Posts
