1 - 13 of 13 Posts
Hey me again,
I need to replace some siding where this dryer vent is and have decided to just move the dryer vent over about a foot to make it easier to clean. Which is a relatively easy job however I am concerned about wiring being in there and how do find out? This is a 1994 Bonnville Manufacturered Home.
Thank you.
654724
Maybe use a circular saw set to the same depth as the siding thickness, and cut a small opening in the panel you’re going to be replacing (if you don’t know how thick it is, start with a very shallow setting). Reach in with your hand or a stick or look with a flashlight and see if anything is in the way? I would guess you’re replacing two panels since the seam goes right through the center of the vent, so you should have enough space for a good size hole.
Very good. Thank you
Invest in a oscillating saw. You can get them relatively cheap and they are pretty nimble when cutting.
Circular saws and jig saws need room to maneuver, and a reciprocating "Sawzall" can easily cut too deep when you are concerned about wiring.
An oscillating saw only needs the with of the blade to make a hole. Many of them have adjustable depth stops as well.
You will use it more than you think.
Premium Member
Of course, the question I have……is everything going to line up? By that I mean do you have a straight shot to the back of the dryer or will you need a flex tube to make the connection to the dryer? Something to consider before you get too crazy making new holes.
If your dryer is natural gas, I believe there will be regulations and codes as to where you can put that vent. If you put it too close to a window, you could fill your home with exhaust gasses.
Discussion Starter · #10 ·
Yea the flex vent has plenty of room to move. Good point. Thanks
Discussion Starter · #12 ·
Always start on the inside where mistakes are much easier to fix.
Good idea!
I will check into that, I don’t have one of those and I did consider a sawsall but knew it would be difficult to control. Thank you.
1 - 13 of 13 Posts
