SP,
Just to recap, installing a 1.5 ton mini-split heat pump AC unit; Power supply (V, PHASE, Hz) 208/230,1,60 Max. Fuse size (time delay) (A) 15
What's time delay mean?
So I am running I believe a 2 pole 15 amp breaker, 60' feet from panel to the disconnect and you say Romex 12-2 awg wire will handle the required loads without any problem. Can I use the same wire unsheathed from the disconnect to the outside unit inside the whip? Or does that require THHN wire and if so why?
Carpenter by trade so a little out of my profession.....Your input is highly regarded. You are licensed electrician correct?
Thanks
Handle
