Licensed Electrical Cont.
what size wire can i use to hook up 250v electric griddle?
The voltage is only half the equation. As Brric asked, what is the wattage (or amperage), and what is the actual voltage of the unit (it's not 250)?
Also, where are you located?
" Euro " electrician
Both guys hit the nail right on the spot for state side the 240 volt gridditte tyically hardwired simair to the electrique cooktopper is.
However European side it common to see it in either portable or perament unit and they will come 2400 watt or more depending on model.
Merci,
Marc
