1 - 14 of 14 Posts
I don't think it will work.
First the generator rating of 1800w is most likely the starting watts, not the running watts which is probably 1400w +or -. It is probably 120v only.
I would expect a real 2.5 hp motor on a submersible well pump to be around 2500w plus or minus, depending on effeciency. It would most likely require a 240v supply (230v rated motor)
· Licensed Electrical Cont.
I want to buy a generator to power my 2.5 HP in ground water pump. I'm looking at an 1800 watt generator. Will that work?
Thanks.
Is the pump 120V or 240V?
2.5HP is only part of the equation, in fact, knowing the actual amperage would be much better.
I HIGHLY doubt a 2.5HP pump will be 120V. In fact I almost guaranty it's not. And an 1800 watt genset will almost certainly be 120V only.
· Semi-Pro Electro-Geek
I'm with Bondo - 5kw should be about right. A 2.5HP pump will use about 2.5kW (probably a bit more at full load), and a generator capable of twice the load will be satisfactory to handle the startup surge. You could probably run it on something smaller, but it will increase wear on the generator and you might run into problems overloading when the pump starts.
· Master General ReEngineer
Ayuh,.... I run my 240v submersible on a 5000watt gen-set,....
I'd be more worried 'bout burnin' up the Pump with a smaller gen-set,....
Electric motors don't like to be fed substandard power, they burn up,.....
A gen-set is at grade, 'n easy to change,...
Pullin' a pump outa the well ain't so easy,.....
1 - 14 of 14 Posts
