I took down my plaster ceiling in order to, among other things, install recessed lighting.
The joists are in good condition, there was practically no dust or debris, none of the joists were rotted, cracked, notched, or otherwise in need of repair. Some are slightly uneven with the rest. On an exterior wall near the chimney it appears that some efflorescence made its way to the wood, but I think the problem has been taken care of. I did find a paper bag full of L hooks between one of the bays that probably dates back to the 20s, so that's cool.
The attic above is insulated at the rafters, and the only layer of flooring is ⅝” doug fir tongue and groove. If I finish the attic in the future, that’ll come up so a proper sub floor can be put down, so I can insulate then if necessary.
So, is there anything I should do before closing it up with sheetrock? Should I add more bridging or blocking? Insulate the top plate with rigid foam? Just leave everything alone?
Thanks in advance!
Thanks in advance!
