1 - 16 of 16 Posts
· Retired Moderator
Those are 1950s/1960s vintage---my guess ,from the profile, is that those were beveled with a table saw--then rounded slightly using a sander--
Matching that rounded bevel with a router might be difficult--if you are going for a perfect match.
· Retired Moderator
Looks like a rabbeted cabinet door, you need to do the round over first, then rabbet the door with a table saw, the round over will prevent the use of a hand held router, but you could use a router table to make the rabbet.
Just reread your post, looks like Canarywood1 answered your question.
Discussion Starter · #8 ·
1...better table saw blade...60+teeth
2...zero clearance inserts
3...1/2inch router bits designed to minimize tear out...especially on the rabbit
4...better wood for drawer fronts.
5...,..........
Sent from my SCH-I545 using Tapatalk
· Property Mgt/Maint
Could be a bevel and sanded and many layers of paint or a portion of a large round over bit as suggested above. Assuming the later, a router table with a fence is key. This will allow you round the edge without making either side of the radius tangent to a edge. By using the depth control on the router and fence position you can position the radius on the edge to mimic the sample.
If you try to do it with a free hand router, a round over bit and bearing follower, the radius will turn out tangent to the edge.
obviously the rabbet is half the thickness of the 3/4" door, or 3/8". this leaves 3/8" thick for the lip. it is not a complete round-over, so its not 3/8" radius. trying to sand a consistent edge is not recommended.
agree with canarywood, it appears the profile was achieved by using a portion of a larger radius round-over bit, and it is best done on a router table.
Discussion Starter · #11 · (Edited)
Yepp....but my most pressing need is to update both my router bit...the mortising one (I have router table and fence btw) and my table saw blade. Ive learned that certain router blades reduce tearout by their design. Not so much the roundover bit but the rabbet bit. My table saw blade has far too few teeth as well so moving up to a 60 or 80 tooth saw blade for these applications.
Discussion Starter · #14 ·
I'm wondering about the ripple effect along the edge from using the table saw. It seems to make circular motions along the edge of the piece and I wanted to level it out as much as possible in the easiest manner possible. Baseball bat Wood
1 - 16 of 16 Posts
