We have a small backyard bldg we call the garden center, since I built it from a kit and I refuse to let my wife call it a shed, even though that’s what it is. It’s on a gently sloping grade, with one side on its foundation almost at grade and the back diagonal corner level with the entire floor, of course, but now about 12” above grade. So, there is plenty of slope for runoff.
Trouble is, surface runoff and/or groundwater is still causing the foundation and floor at grade to rot, over about ten years. So I need to redo part of the inside floor and I also plan to install a simple gravel free French drain around two sides, to the lowest point at the back corner. I can do the carpentry and I know how to dig and install the French drain. There’s plenty of room on our property for me to run the line well away from the back of the garden center and terminate it where outflow would not do any damage.
My question is: what sort of outlet should I put on the end of the drain? Should I use one of those green popup gizmos like my downspouts end in? Or something else?
