1 - 7 of 7 Posts
I'm moving a toilet, which means I have to tie into the main sewer line.
Also, I've never done this before.. I'm not a plumber, so please be kind
I dug down to the sewer line closest to where the toilet will be installed and found this:
To the right heads out to the street and the sewer. To the left is the rest of my bathroom and the end of my house.
The plasic pipe is the shower & sink drain for the bathroom. The toilet is currently a few feet to the right, but in order to move it would require me cutting supports to have it drain to its current location.... which I'd rather avoid doing if possible.
Anyways, What kind of wye would I need to basically replace that fork that's currently there. I'd leave the 2" drain, if possible.
Thanks for your help.
Please let me know if you need more information
Discussion Starter · #2 ·
I was thinking it might be best if I used a 4" tee leading into a 4" 45 degree elbow and couple that to the end of the pipe before the cast iron wye where the 2" is. That would put me slightly to the left from where I want to be, but I'm sure I can work that out.
Does that sound like the best solution?
Nope... I'm quite sure it's from left to right.
It looks like the 2" was installed backwards. Someone recommended I cut on the other side of the 2" wye and replace the whole run... which I might do.
Premium Member
Flow direction of that wye is right to left. Is that building drain a 3 or 4" pipe? 3" is minimum for a toilet.
I'd cut down stream of that wye, attach to the pipe with the new fittings and route it to your new toilet. Tie in the existing 2" where possible.
Discussion Starter · #6 · (Edited)
I stand corrected...
I dug out quite a bit more and got out the level. Sure enough it runs right to left.
It's kind of odd because neighbors have told me that the sewer is out in the street (which would be to the right). To the left runs to the rear of my property. Oh well... you live, you learn (I only bought the property last year)
The building drain is 4"
I suspect I need a 4" x 4" x 4" sanitary wye & street 1/8th bend or sanitary combo to create the vertical stack for the toilet, then I need a 4 x 4 x 3 sanitary tee to be placed vertically where the 3" runs to the toilet?
is that correct?
Thank you for your help.
1 - 7 of 7 Posts
